mk1 caddy
(In Topic #85914)
mk1 caddy
blocks
Its the same ones used on mk1 Escorts.
Amit
Re: blocks
bens_cab said
i think the way its doen these days is to spin the rear axle upside down and cut and weld the u bolt plates try www.caddyforum.com some good info there mate :wink:
bty.. you dont actually flip the axel.. or the brakes will be upside down.
You just put it on top of the spring instead of the underneath.
You have to cut the sadles and shock mounts of and re weld them below
Amit
lol
there was a thread on vortex about lowering caddys using a lowering plate on the rear hubs so a piece of sheet metal quite thick bolt that to the rear beam then bolt the hub higher up :? crazy yanks it would last about 3 bends in this country unless it was 3 inch thick plate
on the caddy forum.. al the forum admin offers lowering plates, or axel flips as lovering options.
with lowering plates tho, the track is widened at the rear due to the thickness of the plates.
Amit
Amit said
get them from rally designs.
Amit
ideal thought the axle was wider on the caddy than the mk1 escort
