mk1 cabrio conversion advice
(In Topic #132353)
im looking for some advice on the following items please
Can i fit a mk 2 16 v master cylinder and brake servo unit directly onto my mk1 , do i need any other mod ?
what size master cylinder would be best 22mm , 24mm or what ?
can i fit a mk2 or mk3 front disks onto the front ?
can i fit a mk2 or mk3 complete rear beam with disks to a mk1 i want to upgrade the brakes to disks , ?
can i fit a mk2 16v power steering unit to my mk 1 as i have all ready changed the engine and box and drives ?
can i fit a mk2 electric window set up into my mk1 or do i have to modify anything else ?
what else do i need to wire vdo clocks , ive only the bare clocks ?
any help please ,
colm
2. 22mm one mk2 16v/g60
3. mk2 yes, i assuem you mean you want bigger brakes if so again this has been covered many, many times. search, look at the faq and tech sections
4. no, just the disc setup. see 3.
5. no, see 3
6. no, but mk1 cabs did have factory fit leccy windows so get a mk1 cab kit
7. how do you mean? mk1 clocks just plug straight in. do you mean you want to get mk1 mfa working, or do you mean you have mk2 clcoks
MK2 servo and master cylinder onto mk1 HERE
MK2 brakes onto MK1 HERE
rear disc conversion HERE
MK2 power steering won't fit, you need a vauxhall corsa electric steering coloumn and a whole lot of fabricating or the conversion i did HERE
electric windows can be brought, or i have seen home made ones (all very good) using windows regs from most early vw's with electric windows, even seen one done with alfa parts , search on google
vdo clocks, i take it you mean the 3 in the centre console ? if so which ones are they ?? there all pretty basic to wire in
Matt
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
