Mk1 2Ovt 8mm Gap And Modified Mount Question :dontknow:
(In Topic #100908)
Whats everyones best views or ways on creating or measuring the 8mm gap for the timing belt tensioner (basing on mk2 16v kr tensioner) washers or bolts? if so what kind and were could i find it or them??
Also Ive been trying to get a hold of the mount from http://vwcaddyforum.com/showthread.php?t=14911
But have had no reply for a while now!
Anyone know anywere else???
Once again everyones opinions and help counts and will be appriciated!
Hows Things mate?
I tried ebay previously for the mount and found one and posted it here for others, I recieved a reply from someone telling me that they had not recieved it, so i got a bit concerned.
As for the cam belt stud do i need to tighten it right into the engine block or not, mainly to allow enough threads for the nut to go on the other end to secure the tensioner??
Ta
:mrgreen:
It was me that ordered the mount off ebay. It took just under 5 weeks to arrive after I clicked 'buy it now' showing 5 available. Their customer service is outright terrible and the product is about a 6 out of 10. It seems to be ok but compared to the picture on the caddy forum website it looks nowhere near as good. The welds are alright but there is not as much support holding the mount to the backing plate. I'm sure it will do the job fine but then again I'm not building a show car. :wink:
Just to let you know, after calling the guys many times for delivery progress, I virtually have the mount, reason being i missed the delivery this morning but have the tracker no. So i will be picking it up from the royalmail depo tomorrow n hoping its up to scratch!!
Im confident on mounting the engine and also wiring it up but the cooling system is giving me some real scary nitemares.
Please Help Guys!!!
cooling system is a piece of cake
renault laguna top hose
mk2 golf bottom hose
shorten the heater matrix hoses and get 2 joiners
turbo water pipe can be joined into the water outlet on the cambelt end under the throttle body
8) 8) 8) 8)
Good news I picked up the mount from the sorting office today and frankly I cant say even one bad thing about it, the build quality looks great, all the nuts and bolts are there and its been sprayed black!
Bearing in mind I havent mounted it to the block as of yet but am itching to do so :mrgreen:
Starting to feel nervous!!!
Will post some pics of it as soon as I find my digi cam, as it seems to have gone awol!
bens_cab said
if you get a long ish bolt it will only go in so far so you should be able to work out the lengh of the bolt needed i just used a long bolt then cut it and filed it until i was happy
any pictures of this buddy?
8mm billet alloy spacers
You can have one for a tenner delivered…..
Good luck with the install btw.
***PM for all your powder coating needs***
