Mk1 20vt wiring (again)
(In Topic #153319)
Ecu!
cf_emoticons__BangHead:
so with the fuel pump running does it fire? can you bridge the fuel pump relay to run constantly, whilst you get fuel to the rail and see if it fires up then?
guessing ME7 if its AGU.
have a read of this and see if it helps you out, as it sounds very similar.
http://www.clubgti.com/showthread.php?255949-no-spark-or-fuel-pump-in-mk1-conversion
1 - ignition live (from ecu relay ideally)
2 - earth (i run this to battery -ve)
3 - permanent live
4 - fuel pump relay earth trigger, to D/13
67 - sensor common ground (check for continuity to other sensor earths)
t10/14a plug on 2nd loom:
5 - fuel pump live
6 - fuel pump live
7 - earth (i run this to battery -ve)
8 - ignition live (from ecu relay ideally)
9 - earth (anywhere will do)
other things to check, make sure the fuel injectors, maf and lambda heater blue/yellow and red/purple wires are live when the fuel pump is on.
Checked pins 1 to 3, all ok, got good earths and power supply's were needed
Checked pin 67, tested continuity from all sensors to pin 67. Does the ecu earth these sensors!
Pin 4 is not triggering the fuel pump! I have wired a relay controlled by pin 4 (-ve activation) when this relay operates this then supplies power +ve to fuel pump, coils, injectors,lambda,air mass meter,over boost pressure reg. all individually fused. This is OEM set up. I have pay passed relay to get power to all component but still no joy on starting
Checked coil pack supply's and earths all ok!
The only wires in the loom I have not connected are
Pin6 green/brown -instrument panel signal to pin 11
Pin7 yellow/blue-connection to auto box signal 1
Pin8 green-not wired
Pin 10 red/blue-not wired
Pin15 purple/red-petrol vapour canister- I've removed!
Pin18 green/white-not wired
Pin19 green/white-instrument panel plug signal to pin 15
Pin 20 blue/white-instrument panel signal to pin 3
Pin22 red/grey-engine control ECU power supply on starting
Pin 23 red/yellow- connection to auto box signal 2
This engine came from a 1.8t a3 1997 AUTO!
The wiring pin info is from a diagnostic tool we use at work called TEXA it's pretty good, I've crossed referenced the pin data and wiring with auto data 2004 most of it matches etc….
Pin 7 and 23 are connections to auto transmission system signal 1 and2, haven't got a clue what to do with these. The auto box had its own ecu so presuming these are signals to stop starting in gear or something!have tried putting them together when tying to start but no joy!
I've wired the ecu almost like standalone , I haven't used any of the original mk1 wiring or relays as such-got a fused ignition supply from ignition switch, fused supply from battery and the relay activated by pin 4 powers my fuel pump- used original mk1 cranking and cooling fan system tho- is this how standalone management would be wired!!!
I've connected pin 22 to my starter single wire this becomes live on cranking, don't know if it this was correct put still never started! The main issue is I'm getting no -ve activation on pin 4 to power the fuel pimp etc… I'm unable to test trigger earths from ecu to coils to even know if its sparking! I've got a feeling the ecu is immobilised ,but everyone's saying it should start and shut down! Sorry for the essay thanks for your help guys….
6 - rev counter, run that to adaptor:
http://www.edition38.com/forums/index.php?showtopic=440379
7 - cant find in my diagram, i'll take your word for it
8 - aircon, not needed
10 - aircon, not needed
15 - carbon canister, not needed
18 - mpg signal for mk4 clocks, not needed
19 - diagnostics, run this to a vag-com port but its not needed for car to run
20 - speed signal from dash, probably not needed (wont stop it starting, but mixed info if it casues rev limit/limp or not when missing)
22 - cant find, must be auto?
23 - cant find
as long as you have power and earths to the pins i listed it should work, so i think its down to 1 of 2 things. either the ecu has blown up which is quite common, or its because it cant talk to the auto box. however, if the ecu itself isnt an auto unit its not down to that, as the auto pins you listed are not even present in a manual loom so dont need to be wired to anything.
even if the ecu was immobilised the car would still prime the pump and fire up for a few seconds before cutting out, so its not that either.
I'm currently tryign to find out if there is any auto/manual switching you can do, but if your ecu is manual already then let me know!
with ignition on do you get a buzz sound from the engine bay? as if something is doing something? i'm not sure what it is, injectors maybe? but I only got this with a working ECU, with my damaged ECU the bay was silent.
you checked for a spark whilst cranking?
as my engine had been sat for a while, i used some ezi start to help it along whilst cranking to fire up the first time. I sprayed it down the take off for the servo line.
if 2 ecus are doing the same thing either you blew them both up or there is summat wrong with your loom. the main thing is it should prime the pumps if you have wired the ecu earth trigger properly.
thing is though if all the pins above check out then I cant see what it could be wiring wise, i think it might be worth removing the loom and unwrapping it again, trace all the wires from the ecu plugs looking for any shorts. check ecu plug pins are all straight as well if any have opened up they wont make good contact.
get the diagnostics working too, see if you can talk to the ecu(s)
my pump doesn't always fire up when the ignition is turned, perhaps the system is pressured?
anyhows you got a spark?
fuel out of the injectors?
what do you think is stopping it from firing up?
try a bit of spray in the manifold and see if it wants to catch.
like i say my fuel pump doesn't always buzz when the ignition is turned on.
so back to basics for any engine.
spark?
fuel at injectors?
you obviously need both of these for it to work.
mine had been sat for a ages (years) unused, so when i finally had it all ready to go (having sourced a 2nd ECU), I found some ezi start was needed to help the engine along in getting going. now it starts fine.
I found with my dead ecu i couldn't get any of the pin outs to work, no voltage at coils or injectors.
I am really out of ideas on this one…. Anyone local to brum….. Thinking of going aftermarket… What people think……. Oo and the battery's ok..
Fuel pump should just prime then go off till you start the engine.. im guessing the pump wont start till engine is running, will prime everytime you turn the key thou
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
