Mk1 16v
(In Topic #75510)
Mk1 16v
16 VALVE
your going to need a 4 branch manifold which will be your most expensive part
you will need to change brake master cylinder for a mk2 1 so it misses the dizzy
gearbox use a mk1 gti as i think corado is cable change
anyone else with sum advice for this guy :dontknow:
16v
choice of exhaust manifolds
ashley mild steel
supersprint
i got a ashley which i bought second hand (wouldnt buy one new) ok quality but the supersprint is the better one
Yea you need change mastercylinder to clear dizzycap ,also may need right angled cap from pug or mk3 golf check clubgti website.May be worth fitting larger servo from corrado
I ran mine with mk1 1800 box for 18 months with no problem,but now gunna fit 16v box with larger cabby driveshafts
mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
You could use the corrado exhaust manifold if its the same as a mk2 golf one and have the down pipe modified with a slight kink.
The metering head will go onto a cut down mk1 airbox on the o/s chassis leg, or you could splash out on a 16v scirocco set up with manifolds etc.
?200 is well cheap though.
if so it might be worth your while because you can sell the extra stuff to pay for the extra bits you need which arent on the corrado, you dont actually say how complete the corrado is tho so dont know your position regarding this.
However tho if your prepared to travel and willing to spend a couple hundred more my cousins converted mk1 16v is up for sale in the appropriate section and comes with all the extra bits youd need for the mk1 conversion(except the gti fuel lines which i pinched but youve allready got)good engine,(chains and belts done last year during swap), gbox, d-shafts and brake conv.
it took a knock in the rear quarter so nothing mechanically wrong except panel damage and mibs a bit of a rear stub pin knock(would need trailered probably).
I know youve got the corrado engine lined up but the amount of spare/new bits you also need extra to the donor for the swap is pretty substantial really and this being the third such swap ive been involved in(my brothers convertible 16v, my mk1 jetta 16v and his early 5drmk1)know how easy it is to become de-railed by missing/needed bits which rapidly bang an engine swap over budget
there are quite a few parts youre missing from just using the corrado gear but this engine is definately my favourite swap into a mk1 and always wish vw had actually made one for proper
Mine will eventually run on throttle bodies but i will runn it in on k-jet to begin with as the engine needs running in
I was advised against bending fuel pipes but instead install new ones to correct side
As for manifold i'm using a rocco 16v manifold and downpipe as i want to stick with oem parts for reliability
I will use cable change box,again,for reliability reasons but will convert clutch for cable instead of hydro
As for shafts i'm using 1.8 gti shafts and will change output flanges on my box to accept 90mm inner c/v joints
PM me if you want to go rocco 16v exh manifold route as i have one spare 8)
Ian
My mk1 has been off the road for a couple of years, but I now have the money and motivation to want to get it back on the road. At the moment the car has a tweaked 1800 8v engine. Unfortuantely the crankshaft bearing has gone, so I either need to replace the bottom end or I am tempted to install a 16V engine.
If I was to install a 16v engine, I am worried about bending 23 year old fuel lines, so would prefer not to do that. I know you can buy a scirocco set up, but that's mega money and there doesn't seem to be any for sale anywhere??! Is there a way of extending the the original fuel lines to the other side of the engine bay, or do fuel lines designed for a mk2 16v that will fit??
Hope you can help. :wink:
Anthony.
Living in sunny bournemouth 8) You jammy tinker!
If you`ve got the time `n` money, go the whole hog and stick a 16 valver in; as you`ll probably regret not doing it if you fix your 8v.
Get it done over the winter, then you will be able to show it in the classic car parade that they have over the summer next to the sea life centre!
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
