MK1 1.3 Driver Engine Swap to 1.6 GTi
(In Topic #86818)
I was wondering how difficult this swap is going to be. How much modifing will be needed. Will it be a case of welding new mounts or should i bother?
Any constructive suggestions will be greatful.
Here's an approximate list of things you'll need, off the GTI:
Fuel tank
Fuel pump
Fuel accumulator
Fuel lines
Fuel pump relay and electrics (fusebox??)
Airbox
Gearbox
Driveshafts
Most of gear change mechanism
Exhaust
Desirable:
Dashboard
Brakes
Wheels & tyres
Suspension
If the GTI is rotten but the engine/mechanicals are fine, and the Driver has good bodywork, it might be worthwhile. Will be worth making sure you can insure it, too.
The guy i bought it from had recently put it in a mk1 he got from a scrappy and his feet went throught the well when he stamped on the brakes so the car is a gonner.
Im gonna need most of the fuel system, ive got the airbox, gearbox + change mechanism, driveshafts and exhaust.
Will the front suspension system be compatible?
If you can source that from the donor GTI then it should bolt straight on - it's probably worth changing the bushes all round, and renewing the top mounts - get genuine VW or Febi ones, not cheapo ones from GSF
The rear is also 20mm lower, and again has an anti-roll bar. It's easy enough to retro-fit the anti-roll bar to your rear beam, but again getting the stuff from the donor car would be easier.
HTH
Rich
