MK 3 2 LITRE 8 V INTO A MK1, ENGINE AND LOOM....EASY?
(In Topic #128465)
GOOD MORNING ALL, IS IT EASY'ISH TO FIT A MK 3 2 LITRE GTI 8V ENGINE INTO A MK 1? LOOKING TO PUT THE FULL LOOM AND FUSE BOX IN TOO WITH THE MK 3 DASH. ANY1 ELSE DONE THIS BEFORE?
engine is bolt in fitment, wiring for engine and dash require splicing. you could fit the entire car loom plus fusebox if you wanted, then it would just be a little bit of splicing for the lights and other few bits that you need to keep from the mk1
yep johnny's spot on i've got a mk3 8v with full loom which isn't too difficult (can help with diagnosing problems further down the line) isn't the mk3 golf dash a bit big for the mk1? I opted for mk4 polo dash which works pretty well you aren't talking big power gains but very driveable, if it's a small engined mk1 you'll need to move the cam belt mount to the gti positioning
if it\'s got tits or tyres it\'s gonna be trouble
Thats great, got it today so will be starting it this weekend. Im not sure about the dash, gonna give it a try and thanks for your help.
well, i didnt realise how much you needed to change on a mk 1 to get a mk 3 engine in! polo dashes dont fit, had to cut 2 inch off the back just to get it in so it didnt hit on the column stalks, then chop away loads behind to get it fitting right!, fuse box doesnt fit right, full throttle pedal assem has to be changed and welded in as the mk 3 has a shorter accelerator cable and is totally different, you dont need to cut the chassis leg either to get the alternator in. What a job!
you know you can use a mk2 gti throttle cable, that would fit both mk1 pedal box and mk3 engine. and with alternator, simply swasp it for the earlier type with the big spring underneath. the later setup with seperate tensioner wheel has no clearance to chassis leg, spring one has loads of room.
but oh well, too late now lol
ahhhh i see, that makes sense now, engine is the earlier type lol. All running now, just brakes to do
is there any issues with the block height in a mk1?
also could k-jet be used on a mk3 engine?
block height is an issue for some aftermarket 4 branch manifolds, but oem setup should work ok
i just used the standard mk 1 manifold etc...
