lowering help
(In Topic #84337)
lowering help
i am fitting new shocks and springs
suspension
i have looked in the manual, i am a bit stuck on how to undo the nut ontop of the suspension.
Re: suspension
alastairant said
they are not coilovers, i just need to now how to remove the old ones.
Ideally, you'd relieve the tension using spring compressors, then undo the bolt by using a special or adapted tool to undo it, while holding the shock using an allen key or head head tool. I made my own tool, from a 22mm socket, by grinding 2 flats into the top of it so I could hold/turn it with a spanner.
Whatever you do, make absolutely sure you use spring compressors to compress the springs adequately before you remove the nut on the fronts. You can get away without doing it on the rears.
HTH
Rich
<a><img></a><a href="Login to a private Photobucket.com album
