Intercooler Dimensions
(In Topic #148502)
the standard AGU/1.8T/20vt intercooler is a side mount with dimensions
183mm x 190mm x 85mm = 2955.45cm2
so i am assuming to fit a 20vt into a mk1 the existing intercooler cannot be used to do location and size etc.
everyones saying use a sprinter one, but the size and dimensions for that is
815mm x 190mm x 85mm = 13162.25cm2
hugely different, with more piping in the mk1, isnt this a massive loss in power? and should an intercooler which has similiar total volume be used?
Birmingham
The sprinter ones are massive and overkill IMO. Have a read of my build thread there's a bit in there about intercoolers. I have one for sale too.
Smudger
http://www.toyosports.co.uk/fmic-ffront-mount-turbo-intercooler-type-f-410x155x65mm-5799-1042-p.asp
http://www.toyosports.co.uk/fmic-ffront-mount-turbo-intercooler-type-s-550x140x65mm-5999-605-p.asp
they fit nice in front of rad.
also piping kit
http://www.toyosports.co.uk/25-turbo-intercooler-pipe-piping-diy-kit-64mm-blue-6499-1045-p.asp
what turbo you running? ko3 or ko3s 2 inch or 2.25 piping be best. the ones above are 2.5ich as im running a k04 hybrid they do sell 2 inch and 2.25 also they in brum can collect
657mm x 157mm x 40mm = 4125.96cm2
Birmingham
http://www.ebay.co.uk/itm/230879020680?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
This seems okay, decent end tank design:
http://www.ebay.co.uk/itm/HONDA-CIVIC-ALUMINIUM-BAR-AND-PLATE-INTERCOOLER-/350444717297?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item51982204f1
Not too keen on the intercooler you posted, too much restriction on air flow as it has to turn on entering the cooler
Birmingham
With the tubing being bent outside the end tank you can substantially reduce the angle although there are always packaging constraints.
I'll dig out the flow dynamics tests i've done but I can always change the values to deal with various orifice dimensions and flow rates.
This is something like using wider intercooler tubing to a narrower one then to a larger again like a throttle body, or simply a bump in your intercooler piping.
Various values are inputted to see what flow is like and it gives you a timed performance
When the values are changed like velocity or even the chemical composition it produces reactions and changes, this VR6T one was for FI I did a while ago and heat build up from restriction can be seen a touch compared with above (more red)
Values are changed further (I think in this test it was to simulate an increase in boost/velocity) and you can then see at what point changes occur like restrictions/turbulence etc
As said this was just some 2D flow dynamics testing I did ages ago but it gives you an idea of why tuners go for less bends or less sharp angles.
