inlet manifold help
(In Topic #121980)
inlet manifold help
Website Manager
At the same time I would add a WUR that has the fuel enrichment capability when the throttle is pressed hard, like the 16v mk2 ones. Also gives you the opportunity to tweak the control pressure for better fueling, you will need a fuel pressure gauge to set this - commonly known as the "WUR" mod.
