injectors
(In Topic #74950)
injectors
You could get higher flowing ones that are used on saabs or even porsches.
Mk1 Lahsa green, BBS RM, Mk1 Silver Campaign, Mk5 GT TDi, Audi A4 Avant S Line
mk1turbo said
Ket jet?
Tell me more
Which models?
Let me know please.
Need more info to take the plunge and buy themsmithysmoo said
MAte did you sort your injectors out, I'm needing new ones and wouldn't mind putting porche ones in for better performance.
Let me know please.
To get more power, you need more air (or more oxygen in that air) to match any increase in fuel…
*BSFC is the amount of fuel your engine uses to make 1 horsepower for one hour. It is usually between 0.42 and 0.58 at wide open throttle. Normally aspirated engines with efficient combustion processes are at the lower end of the BSFC scale [~0.45], supercharged engines tend to be towards the higher end [~0.55].
Careful on oversizing injectors though as you will loose the fine tuning capability at low loads/revs .
I tried using Porsche parts on a standard 8v engine , diddly squat , hassle etc etc , so now running back as it should be [the bits were free so i had to have a go]. Standard engine stick with the way VW intended , modified and you have plenty of money then there are loads of tuning firms out there who will advise . The blerb at the top was sent to me when i enquired about larger injectors , i still DO NOT understand it 8O
Cheers………..
