How do I change my GTi Cab from K-jet to twin 40s
(In Topic #120354)
Also one other odd thing, when filling with petrol it takes forever, the pump keeps clicking off and I have to hold the nozzle half out - any ideas?
Oh and the brakes are rubbish - what is the best way to make it stop….
Hope you can help
Greg
Website Manager
Oh and be prepared to visit the petrol station a lot more often !!
I run 256mm disks with Mk2 16v calipers and Audi carriers up front. Mk3 disks on the rear. A 9" mk2 servo and 22mm master cylinder. Goodridge hoses all round and copper nickel brake pipes. Fluid is Dot 4. Brakes are superb !!
Greg
Website Manager
Greg
They aint an easy step or cheap run in terms of fuel consuption and set up costs.
The 8v don't have much room to work on them either.
There's no way you can just bolt them on and go!
Power can be increased or lossed dependent on the set up of the carbs.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Haynes ISBN 1 84425 101 2
Tim's advice is essentially as above (ie POSSIBLE but NOT RECOMMENDED). There are lots of problems that are not readily obvious (like finding space, bunging up the Injector holes, new pump (approx 4 psi - not 40 psi !!!!) ad nauseum…….
Book is worth having as it also explains in detail about stopping your car
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
