How 1.8i engine is mounted in cab?
(In Topic #81278)
one point is gearbox and one in front, but what about the rest?
pics would be great
pics would be great
I'm assuming that Cabs have same mounts as tin tops….
1. Cylindrical mount on Driver side next to Cam Belt Cover.
2. Cylindrical mount on Pass Side end of gearbox.
3. Lower Rear mount on back of gear box.
4. Front 'steady', mounts between starter motor bolts and front cross member.
you can see the on this pic (of a 16v, but with mk1 mounts on)
The clylinders on either end of the engine/box are the side mounts, the Red Cuboid is the Rear Mount (poly in this case)
And you can 'just' about see where the front is on this on, right at the bottom of the picture
Do you have pics of this mount?
I think it's the missing one….
thanks a lot!
good link that!
