guages
(In Topic #104537)
guages
Just a little different idea. The DVD player has since gone, stuck out to far and was crap.
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
iirc you need a T-piece adaptor and 2 senders, one is an original one from the car and another that can cost upto ?100 i think
will have a look for you - as i need the list again!!
http://www.egauges.com/
Quick delivery too, being as they send it from the gud ol US of A! Genuine VDO aswell.
Try these too.
http://www.etbinstruments.com/Sensors_ancillaries.htm
doogle said
how are you guys measureing oil pressure? have you got electric guages or is there an oil way/plug/sender on the block/head somewhere?
i have a sender above the oil filter and there are high and low pressure senders on the side of the block i think (i am prob wrong as my knowledge is limited)
these work with the buzzer and light on the dash
Old:
New:
All the different ways and feelings a side, location should be well though out before doing the work. Attached to the filter bracket will give you oil pump pressure, call it system pressure like in a CIS fuel system if that helps. problem with that is that if the bearings start to wear thin or there is a blockage in the cylinder head starving say the camshaft, you will not know it untill too late. Many people don't care and use that location anyway, but I suggest using the location on the driver's side of the cylinder head. That location is at the end of the oiling system and will show a problem anywhere in the system.
as it comes in the sequence of dash lights that have to come on at ignition
- thats what my tester told me!!
like you can't have abs and not have a working abs light?
han said
but isnt there supposed to be a sequence of lights followed?
If the car has ABS, it must be working. Part of this is that the dash light comes on with the ignition, and goes out once the engine is running - as this is a standardised self-check of the ABS system.
You need some dash lights, eg to show indicators work, fog light is on. Possibly main beam is on, too.
