gti rabbit rear disc help
(In Topic #109613)
from a 87 Jetta GLI. My question is do I need to get a bigger master to run the 4 disc's? Not yet finished bleeding them and seems still to be spongy!
Thanx Dwayne
Maybe I'm just not using it correctly.
So the stock master is big enough!……
mountaintaz said
I bought the hand pump unit that sucks the brake fluid threw.
Yeah the stock master cylinder is big enough, but on the scale of things, a rear disc conversion is quite a 'full on' alteration; and an upgrade of the master cylinder and servo is normally done well before, or as part of a package of changes. There's no one set way of doing things, though.
I've used 4 different methods of bleeding brakes but I've not heard of a hand pump vacuum unit. I guess its similar to a (compressor) air operated vacuum pump - these are convenient but not that great, all told. I prefer plain old pumping the pedal and a one way valve on the end of some clear tube.
I've got rear discs on mine, just word of warning mate, once you get them bled make sure you are very happy with the front / rear brake bias before driving too fast. I did a lot of testing and its really easy to do a 180 in the wet if you have too much rear bias.
Oh yeah, make sure you dont still have the residual pressure regulators still in the rear braklines, these are found under the bonnet on the rear lines and are for drum brakes only.
Sorry if this is all obvious stuff but I found it all out the hard way!
rustyGolf said
Do you have a rear pressure regulater (underneath, connected to rear beam with spring) If you do make sure its pressed in (or out cant remember) when bleading or you will never get the rears bled.
I thought the things on the bulk head were limiters? I have 2 sets in mine with the rear disc conversion,
also you could do with the larger mc, the mk2s had them for a reason and it will help with the feel of the brakes and make the pedal shorter.
and you will need to look into the bias as I will garantee you end up backwords!! I have 280s up front but mine will still lock the rears first. im looking into a mk2 compenator to help with things.
In the end i left them in place but took the springs + balls out so i didnt have to redo my brakelines.
Now i'm just running the standard load sense rear pressure regulator, but have 22mm 16v master cylinder and 256 front brakes. Dont have any problems at the moment. I think if i ran with the rear interior stripped out i would need to reduce the rear bias further though.
There are a scirocco pressure regulators that are meant for rear discs that screw into the master cylinder outlet, tried to get some from vw but they said these are obselete now.
I got some what i belive are limiters from a guy on clubgti and fitted these inline with the rear, and they seemed to calm down a little…but not masses.
I'll let you know how it works cheers!!!!
