Gearbox number
(In Topic #123428)
Gearbox number
GEARBOX
IF YOU LOOK ON THE BOTTOM OF THE GEARBOX…ON THE BELLHOUSING WHERE IT MEETS THE ENGINE YOU WILL SEE A MACHINED FLAT SURFACE ABOUT 20 X 50mm…STAMPED HERE YOU WILL FIND A COUPLE OF NUMBERS AND MAYBE 1 OR 2 LETTERS…..THEN GOOGLE GOLF GEARBOX IDENTIFICATION OR USE VAGCAT AND YOU WILL BE ABLE TO DETERMINE EXACTLY WHAT BOX YOU HAVE,,GEAR RATIOS FINAL DRIVE ETC…..HOPE THIS HELPS…THE NUMBER YOU FOUND IS A VW PART NUMBER
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
