Gearbox / Clutch woes Mk1 16v with a mk2 8v gearbox
(In Topic #123295)
It was running a campaign close ratio box with a 190mm clutch plate but it threw the oil seals out, contaminating the clutch.
Any help will be gratefully appreciated.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
The ends can wear with time, so maybe a just a new std one will do you. I believe they're meant to to be hemispherical, so if it's flattened then it's worn.
When i push the clutch lever its very easy, like the pushrod isnt connecting anything…. and the clutch doesnt disengage, cant believe if this is a common problem it wasnt mentioned in any of the guides :roll:
So by the sounds of it i can remove the cover and end plate have a play and be back in business anyone actually done this?
Im suposed to be driving over to the nurburgh ring in 4 weeks so need it sorted asap!
Any advice much appreciated
1982 Mk1 GTI
Now with 16V
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=52163
Now with 16V
See the link below, it looks to me like there are different size clutch release bearing carriers, im guessing that the set up ive got requires the 24mm bearing and ive got a 19mm one which would make my shaft 6mm short. Suspect yours could be the same.
I will have to investigate further but my thoughts are to shim the bearing with a 6mm spacer or get hold of the thicker bearing anyone any thoughts?
TO Bearing
Ste
1982 Mk1 GTI
Now with 16V
Now with 16V
1982 Mk1 GTI
Now with 16V
Now with 16V
