G-charger on GTI engine
(In Topic #103537)
Block is the same i believe.
Chairman
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Whole load of work though.
youd need to lower the compression - stacked head gaskets is the easiest
an aftermarket ecu like megasquirt including the sensors that megasquirt needs
intercooler and piping
to be able to mount the charger on some sort of bracket
im researching into putting an m62 charger on my 16v at the moment and ive worked out a budget of ?1.5k to do it thats with me doing all the work myself so weigh up how much youd want one. id estimate youd get around 160bhp out of an 8v with an m45 and a small pulley. if you go on the eaton site theres a tool on there where you can work out how much boost and extra bhp you can get out of your engine
dave_dub86 said
it can definately be done - youre better off with the eaton m45 charger from a cooper s much cheaper and more reliable.
you also need to convert to efi instead of k-jet as the megasquirt or any other ecu will NOT control the injectors :wink:
