Fuelling a 1.8t
(In Topic #153349)
Been doing a bit of reading and getting myself confused.
I'm doing a 1.8t conversion like everyone else and I'm getting round to sorting the fuel lines. Can someone please help sort me out.
I've got the filler neck…
I need one of these (filler neck to tank)
http://www.ebay.co.uk/itm/VW-GOLF-GTI-MK1-FUEL-TANK-TO-FILLER-NECK-RUBBER-PIPE-BRAND-NEW-/290821332993?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AGolf%7CPlat_Gen%3AMK+I&hash=item43b64d6001
I have a tank
I need one of these (tank to pump)
http://www.golfmk1.co.uk/Details.php?item=FTPH&group=UNDERSIDEFUEL&cat=SLAREA
I have a pump
I need one of these (pump holder)
http://www.golfmk1.co.uk/Details.php?item=FPB&group=UNDERSIDEFUEL&cat=SLAREA
and (pump foam)
http://compare.ebay.co.uk/like/121073809234?var=lv<yp=AllFixedPriceItemTypes&var=sbar&adtype=pla&crdt=0
I've then read I don't need an accumulator. So what do I need from the pump forward?
If someone could help that would be great
I have also used THESE at the end of the hoses. One bit of advice though, wrap a seal of tape round the end before you put the finishers on as it makes life much easier getting them on and not have braid going everywhere trying to escape.
List looks ok to me.
is the fuel hose about £10 a metre?
Good luck.
smudger1980 said
Yeah it's generic stuff.
it best be for a fuel injection/high flow car or i might as well through it in the bin
dont forget a fuel filter as well, mk2 digifant or mk3 petrol will be fine. as you say no need for the accumulator so you can mod its brackets to hold your filter or just make something up. the mk3 golf has a handy fuel filter carrier under the car you could use as a base.
and yeah make sure the hose is rated for fuel injection
I've bought a generic fuel filter
http://www.fuelpumpsonline.co.uk/ekmps/shops/templetuning2/images/fuel-filter-clips-in-out-8mm-ssfc5160c-1079-p.jpg
I bought this
http://www.demon-tweeks.co.uk/motorsport/fuel-hose/sytec-stainless-steel-overbraided-high-pressure-fuel-hose-8mm-bore
so should be okay?
I've bought the bracket off CQ so will see what it looks like when I get underneath.
Thanks for your help
this is the kind of thing you want for fuel pump:
http://www.ebay.co.uk/itm/M12x1-5-METRIC-to-7MM-8MM-BARB-Straight-Oil-Fuel-Pump-Hose-Fitting-Adapter-/370774482646
or:
http://www.ebay.co.uk/itm/12MM-BANJO-FOR-8MM-HOSE-M12x1-5-BOLT-FUEL-OIL-IN-PLATED-STEEL-/390551013604
this is what I went for
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150914427513
I love spending money.
