From steelies to P Slots
(In Topic #86993)
I am going to change from my original 13'' Golf C wheels to P Slots and wondered if I need different bolts?
Plus, the P Slots have 195/60 R14 tyres. Obviously the rolling radius is a little too big. I was thinking 185/60 R14's instead. Any other ideas???
Thanks in advance
No car ATM!!!!
The 195/60/14's (never actually seen that size before???) would not have that much of a difference to 185/60/14's as far as rolling radius is concerned, though I would say they are too wide for the wheel…
My Build Thread
My car is actually around 80 - 90mm lower than standard, but it doesn't look that much, 'cos the tyres aren't tucked up in the arches. If I put a set of Teardrops/P-Slots on with 185/60/14 tyres, it looks well decked!
My Build Thread
I've worked out I need to get 185/55 14 to keep the rolling radius spot on. So I'm on the lookout! I'm going for a 60mm drop, so hopefully it will look ok. I'd like 80mm but too many speed bumps and a large duckbill on the front maybe a bad combination!!!
Re the bolts where's the best place to get them?
No car ATM!!!!
Any bolts from a Mk 1 or 2 (or even 3 I think) that has alloys on it will be OK. they are just a bit longer - your steelies bolts will fit and catch, but only by about 3 threads.
My Build Thread
