fitting audi throttle 8v gti
(In Topic #131027)
mk2 carb is well, carb. so that wont work will it
rebuild in progress....
Website Manager
cabriaulait said
find an old audi 2.8, the throttle body bolts on, for maximum effect port the manifold and body to match. tis the best cheap mod u can make. hope that helps
It is only really effective if you use the Audi WUR at the same time, it has a vacuum triggered enrichment device, so that banging open your larger second butterfly is accompanied with a little more fuel…
Website Manager
