FIT TWIN CARBS TO 1.8 ?????how and why????????????
(In Topic #88740)
how hard is this to do? and do they come already set up for the fuel/air mixture?
Cheers dudes.
power increase?
givememorepower said
ah.
power increase?
Nothing over fuel injection, they're done for show (cleans up the engine bay) or for the technical challenge/sake of it. I suppose over around 180bhp they can give gains, over & above K-Jet.
where can i find out about sensible engine mods that won't affect reliability on a 1.8 8v please?
The best mod i have done so far.. and that carb i put on came standard with a 2.5 Chev!!
So…
Hope that gives you more of and idea????
The Kronic
96' MK1 1.8
07' GTI W12 Rabbit (ha ha not!)
Kronic said
find yourself a DCD Weber (Down Draft) its the brother to a sidey! except the fuel bowl is on the side of the card! it has a very similer design to a side! I have a 8v 1.8 as well..fitted a 28/36 DCD and oh man wat a difference it made! i couldnt belive how quick my pull away is and responsive the car is! you got to find out wat the write jetting is for the carb.. once that is done you can play around with it.. my fuel 1st was 120 and 2nd was 140.. so i up'd the 1st to 140 and 2nd to 150.. it increased my top end big time!! of course my fuel but wats the fun in running lean!!
So…
The Kronic
Any rolling road figures, or 1/4 mile and 0-60mph times (done at a recognisable facility)?
96' MK1 1.8
Kronic said
at the mo i got a 15.08 out of her which is pretty dam inpresive i say! but she is going in for a big big change in the next 2 months once all the parts are seleted and put 2gether then i should knock that down 2 13's!!
Nice time! I think a stock GTI is 16.4 or thereabouts. What other mods have been done to achieve that too,or was it all down to the carbs?
96' MK1 1.8
I had a 1600i 2001 Toyota Tazz.. she ran a 16.7 and that was with only a back silencer replaced!!! and my golf runs away from it.. but top end the tazz comes and gets the golf…. so its all weird and fun at the end of the day
96' MK1 1.8
As far as Webbers go. 40DCOE are going to give you good mid range punch. If your planning to drag race it and don't mind loosing some mid range, you could consider 45DCOE. The side drafts are really awsome sounding and very reliable and easy to tune once set up right. There is lots of information avalible on what you need to put in them as far as jets and airbleeds are concerned.
I've seen motors built on the ABA block and 8 vlave head with sidedrafts. This motor I belive has the oil jets in it to help keep everything lubed at high speed. So in that respect it's a lot like the G60 or the new 1.8T.
Good luck
