Engine Conversions
(In Topic #141505)
Engine Conversions
What engine conversions are possible with this setup? From what I have read you cant do as 'simple' a swap as if it was a 1.3 or a GTI because the 1.1 uses different mounts.
Would putting a 20vt into the car be more-or-less the same as putting a GTI into it? I.e having to make mounts? (By which I mean the mechanical means not the wiring or fuelling).
Also, what do people do about driveshaft lengths when these conversions are carried out? Is it pure coincidence that the driveshaft lengths are the same and no shortening needs to happen?
1.3 use the same mounts as the 1.1.
G40 lump would drop into the 1.1 mounts, just the gearbox mount to sort out, easily done, cut them in half and weld together the section of polo and golf mounts together.
driveshafts depend on what box you use and its not lengths but size of CV's/hubs that cause a problem.
for my 20v conversion, i've used the 02J box with 100mm flanges, with 100mm driveshafts into the later cabby 100mm hubs.
saves the faff of turning down the 100mm shafts into the 90mm hubs.
Pretty chuffed about that!
IIRC G40 engines are quite hard to come across now. Would using a G40 engine and gearbox require driveshaft work?
g40 box you'll get to keep the 90mm driveshafts.
