emerald ecu help,
emerald ecu help,
hi guys, ive been running my 1.8t (bam) in my mk1 for over a year now and last week the cam tentioner went and bust all 20valves! so ive now got an auq (180hp) block and head but have the bam internals in the lower block , ive swapped the turbo, inlet, injectors ect from the bam. But the problem im having is the car runs but there seems to be no power and it blows off the tubo pipes. I need to get the car movable so i can get it motd then take it to a rolling road to get the ecu set properly, my knowledge of ecu tuning is limited so any help would be good or if anyone has a map that they use on such alike that would be great, thanks.
Dave walker (aka Mr emerald) would be the best person to ask surely. Never spoke to him myself but I've read that he is a very helpfull man.
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
cheers man, ill get onto it.
needs a map
check n75 valve is working and plumbed in right if its not you will send the ecu into overboost protection causing the car to run like a sack off
