dx head on ex block what needs to be done
(In Topic #134868)
1. remove insert, drop in penny, refit insert
2. swap in gearbox fill/drain plugs if its the right type of head
3. leave the injectors in
swap over all carb bits that differ, you'll need to swap over the fuel pump on the front, inlet etc. also what carb is it? if webber great no problem. if 2e2 then you'll need to drill a hole in the head for the coolant chanel, which might not be possible if its the type of engine with air shrouded injectors.
