Custom Rubber "O" Rings...
(In Topic #96270)
Can't remember the size off the top of my head - need to go and measure up…
Alex
it's a length of rubber and some super glue basicly. you cut to length and glue and hay presto any size you want.
not seen them for a few years but sure there still about.
yeha said
We've just bought 80m from either RS or Farnell. If you ask me nicely, I'll cut some off and send it to you.
Hey that would be fantastic… Thank-you. So do you just keep wrapping the stuff until you get the required thickness?
pm on it's way…
Rich
novocaine said
thats not an O-ring thats a rubber ring. people float across the channel on thinner.
Rather you than me! If the o-ring thing doesn't work I might try filling it up with expanding foam. That should keep it from rattling about…
Always do sober what you said you'd do drunk….that'll teach you to shut up
mack_cab said
I can send you a complete O ring kit various thickness of rubber,glue and even the knife for cutting it. just Pm me
Thanks for the offer, very kind of you but I think yeha can sort me out with what I need…
Alex
novocaine said
thought about using inner tube? you can stack a few circles together if you want it thinker. and no breaks in the circle.
Good idea. Another option to try if things don't work out…
If you do need it all I ask is the postage which I guess would be pretty cheap
Frank
did an oil and filter change last night and noticed that the seal on the filter would be about the right size for what your after and it's flat so should sit abit better.
