Crossflow head
(In Topic #127124)
Crossflow head
I have my 2l bottom end and I have changed to fitting some twin carbs. I am wondering what model the crossflow heads come from so I can fit the carbs on the front????
Ryan
Do the holes just need enlarged?
Is it just a blanking plate on the egr side?
Who did you get to do the work on your head or did you do it yourself?
ya i did the work myself, the head bolt holes need enlarging by 1mm as the head bolts are smaller on the mk4 golfs. i found this out the hard way! as for the egr ports there are 4 small holes on the back of the head about 6mm so i drilled them out and taped them to 8mm and used grub screws and thredlock to blank them off. not all heads have egr ports i found out after but it wasnt a big problem. jay
