Corrado Interior - Rear Bench - anyone fitted one?
(In Topic #97039)
It's going in an '89 Cabrio GTI.
Size wise I am not sure might be a tight fit
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
Also the hump bolts down onto the body in a Corrado so you may have to drill/tap/fit captive nuts in the area under the seat base, in order to bolt the hump hinge down to the body.
Hope this makes sense - when you look in a Corrado you'll see what I mean.
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
a bit of a nightmare to get everything to fit right but when its done its worthwhile
there was quite a bit of choping involved,like the lower cushions were you sit your butt on had to be shaved down to get it to sit right..my lowers are fitted on metal trays so they slide in and bolt down
i followed a guide on matey matey for a mk2,although it isnt quite as easy as fitting them in a mk1
ive seen other people use quicker methods,but they dont look right imo
Need to find a decent set of grey leather now…
