complete 16v car loom in a mk1 carb?I NEED YOUR HELP
(In Topic #98973)
My fuse box has the colour coded connectors on the back. I can get hold of a complete early 16v car loom, included all wiring, ecu, fusebox, idle etc. Will this loom be compatible with my existing switches, speedo, rear lights, etc. Can I plug in parts of my mk1 loom into the mk2 fusebox for say the rear lights, etc.
I have also acquired a lift pump, accumulator and fuel pump from a gti. The lift pump had three connectors, my old one had 2 as the lift pump was not electric. WIll the 16v loom have three also. Because i have limited experience with wiring, i thought this would be the best way to convert especially as mine was a carb model. Any help appreciated as engine has already been removed waiting for my new engine.
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
Re: complete 16v car loom in a mk1 carb?I NEED YOUR HELP
Mk2 item is the same thing as late mk1 item depending on the year [ later MK2 was totally different ] but there are two many differences in the looms . Imagine altering all the dash wiring . If its was me i would keep original loom and add only what parts you need for the conversion especially if your not wiring minded ! Pumps would be easy , just use parts of the 16V loom .
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
just2zang said
spoke to someone at old school performance and he said since mine was a carb, and wanted to run the original 16v stuff for the engine, that it would be easier to do, just change the plugs on the end. doesnt sound too difficult to me as my original looms completely off the vehicle and everything is labelled. Will see when i get the mk2 complete wiring.
Now you've spoken to 2 other people who think it would be harder to do! Its your decision, I'm sure its possible to use the mk2 loom but I wouldn't fancy trying to sort it all out!!!!!
mk4 rear disk
webber carb
mk4 rear disk
webber carb
working on the wiring
found a few wires that were missing from the loom and wired in. Fingers crossed, that it works..
mk4 rear disk
webber carb
mk4 rear disk
webber carb
