coilovers
(In Topic #75707)
coilovers
so has anybody got any idea of which coilovers are best for a relitively small budget??
an cud it go lower on 17's with small arch mods??
any help wud be greatly recived
IMHO 17's are way too big for a mk1 chassis anyway, I suppose it depends if you want to sacrifice handling for looks.
What width tyres are you running, I'm guessing that anything over 205's with correct off set and coventional struts are going to necessitate arch work if its lowered.
Hope this helps.
dint want to guess at how much i cud lower it by just buying a set of shocks and springs,,
so i thought coilovers wud be beta, so i could make it stiffer, without nesesceraly making it any lower,
or am i compleatly off the mark?? :dontknow:
Will be plenty stiff enough for you.
My Build Thread
The ones i went for were the fk highsports from venom, 420 quid.
What you mean about more clearance issues with coilovers, surely the smaller dia of the shocks the more inside clearance your gonna get! As they are much smaller than standard shocks and springs?
Btw 225's are a bit on the large side what widh are the rims>? :dontknow:
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
With Coilovers, the spring is longer on the strut and sits behind the actual wheel and tyre, though with the standard struts, the spring seat is higher that the top of the tyre, therefor you only have the diameter of the shock to wory about.
When I put my coilies on with Teardrop alloys, the front tyres fould the spring seats. With the alley cats I have on it now (they have a smaller offset) I have still only got about 3 to 5mm clearence!
My Build Thread
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
biggaz said
Well ive got coilovers on my mk1 and i think tere fine for everyday use, but mines decked, im not going for handling etc as i know ive passed the point of good handling but mainly looks.
I'm not exactly sure how that can be practical for everyday use. Don't you have speed humps or pot holes? :wink:
