coiloveres
(In Topic #96303)
coiloveres
Which is the best set to buy and where from.
thanks
VW MK1 GOLF GTI 83
rustys_mk1 said
i just bought a cheepy set off evil bay for ?200 and so far there absolutely spot on and they got a 2 year warranty and the car is on its botty so all round a pretty sweet deal!
whats the ride like?
alexHxC said
how much u got to spend firstly
About ?450 roughly maybe more. I want the ones where you can adjust the dampening too?
Do these have height and dampening adjustment too? What is the maximum drop on the coilovers?
VW MK1 GOLF GTI 83
Try getting in contact with Phil from club polo.
He sells the cheaper ones for ?200
Plus their on ebay for ?200
As your wanting good quality id probs go for more expensive ones.
I only want them cus its cheap full slammage.
can't adjust the dampening but they drop 120mm all the round which is more than enough IMO and ride is surprisingly nice considerin its as low as it will go lol! just need to put my exhaust a bit higher so it doesn't catch on my drive
also you will get bump steer to hell if you go too low. check that the inboard wishbone pivot point is not lower than the ball joint, this will happen if you go lower than 80mm (est) and your handling will go to shite. you'll also need to get laser alignment (maybe difrnt w'bones +/ adj topmounts),cant quite remember) as the front camber will go massively positive and your tyres will last about a week.
id go for Weitecs, and if someone is peddling 200 quid coilovers theyre either made using slave labour or stolen. you REALLY dont get 'owt for nowt
all from bitter experience
p.s coiloveres ??can noone spell these days (sorry been browsing ebay a lot)
Mk1 '92 cab ABF Jenveys & Emerald
2004 Mk1 Fabia VRS
2002 Audi A4 Avant 1.9tdi
2004 Mk1 Fabia VRS
golf on 16"s on its botty. no scrubbige no problems with bumps handles mint an its a lot smoother than i thought it would be, tis a ta hard though.
check them from germany with ?200 buy it now or best offer
i offerd 145 he said neign then he took 160 (postage was 20) with a 2 year garentee.
i'd get new strut tops front and rear and new bolts too. had to cut the rears with the gas axe as the bottom bolts wouldnt budge with the air gun (only time its ever been beat)
buy em
ill bet that half the slammed cars that end up on their roof are there because of poorly setup suspension
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
As im buying some withing the week so id like to know how to dot it properly, ive put some on before but how would i have not done it properly?
As mines a 1.3 but i do want to go to tracks and put a new engine in it, which will be silly rapid…
So i kinda need to know.
Thanks quick clipper..
fulltiimejunglist said
what would you says set up properly.
take it to someone who has a full on computerised tracking and camber set up(and knows how to use it) pay them about ?60 an hour and it will be fine :mrgreen:
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
its all to do with the relationship between the steering rack and the track rod end,if the TRE is higher than the steering rack you will experience bump steer, the larger the difference the worse the reaction. the only way to combat this if you really want to slam it is to raise the steering rack or possibly change the TRE from mounting on top of the hub to mounting on the bottom of the hub.
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
