coil wiring and other bits and bobs on a 16v conversion
(In Topic #99466)
Also my lift pump only fires intermittantly, i have a new relay. can i run the wire from somewhere else. Currently running from a thick red and yellow wire in the fusebox.
My mfa doesnt seem to function at all. Just getting a clock. Does the mfa only functions when the car is running? Really need a mobile sparky in s.london if i dont get this running soon. Anyone know of one?
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
pump should prime for 2 secs before it fires up then runs constant untill you turn it off.
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
I only have two connectors. A green and a black with a black and white wire
:dontknow: :dontknow: :dontknow:
HOW MANY WIRES?
HOW MANY CONNECTORS?
WHICH wires connect to the smae connector?
i didn't spot that but the wires should be as abovepaul_c said
I am scratching my head cos I don't understand the first post:
HOW MANY WIRES?
one has a green wire
the other has two wires, one black and white, the other just black.
Is there any way to power up the pump from the coil or dizzy? Because there is a similar red with yellow stripe wire i have going from fusebox to the lift pump. I will use this wire to go from the lift pump to the main fuel pump also. Sound about right?
mk4 rear disk
webber carb
mk4 rear disk
webber carb
just2zang said
there iare two spade connectors.
Cheers for clearing it up, yep that's the right connectors. Yes, basically the fuel pump relay is wired along the same circuit which feeds the coil (terminal 15). Fuse box to lift pump is the other side of the relay, and the +12V feed is red/yellow. I don't have a wiring diagram for the later cabby (which has a lift pump and a main pump) but I can't see any issues with powering both pumps from the same circuit which goes from the fusebox to the rear of the car.
