Chip to map timing
(In Topic #87186)
Chip to map timing
Andre
If you want to be able to map the fueling and spark go the electronic injection route and have a look at megaquirt. Fully mappable by yourself. No more expensive trips to the tuners everytime you make a mod to the engine.
Good times!
Andre said
Cheers woza - ill check out megasquirt. Does it provide much of a bhp increase?
Not necessarily an increase in peak bhp (might see a bit) but it lets you adjust the curve throught the rev range to get the most from the engine at all revs…
