changing servo and mc
(In Topic #113627)
LHD 1.3 Cabriolet GL
Sorry for any confusion on whereabouts. ops:
there's a good guide with tips in the technical section on the left hand tool bar.
as long as you mount the servo onto you LHD bracket, you should be fine.
hopefully someone with greater knowledge than i will help you out if need be.
ash x
good luck
Have started to take out the servo/mc-Servo is connected to brake pedal
looking more complicated now.
Will the gti servo/mc fit is the question?
Rod on gti servo is 3cm long, the original servo is 10cm!
This aint gonna fit!
Just gonna change the original mc, and see if that does the trick
