Changing dash bulbs to LED`s
(In Topic #139488)
First option is to upgrade them to 2w items.
Can i get replacement LED bulbs instead?
If so what do i have to watch for, any reccomendations on what to get?
Thanks.
Skid.
http://www.cabby-info.com/Files/InstallingLEDs.pdf
Easy mod, looks a bit brighter. The rheostat on the headlight switch doesnt do much now but hey…who dims their lights??
I looked through that list of bulbs on the "superbrightleds" link but they look nothing like what is required. :dontknow:
Has anybody got a complete list of what type and for where in the car that is required?
They are colour coded for wattage on the base. Green, black, grey?, cannot remember the colours now off the top of my head
makes a slight difference!!!
skid said
I am wanting to keep original look,
LEDs produce a brighter white light very artificial.
Not really original look and as these can swamp the area. It will be a balance to get the origional look right. Hence using bulbs so they give a softer origional light.
chortle said
You can just swop the bulbs over from 1.5w to 2w. etc.
From “Changing dash bulbs to LED`s”
Quite a few MK1 dahsbords have set on fire including mine because bigger bulbs were used and put too much current throught the circuit so I wouldnt recomment it. It melts the wires between the dimmer on the headlight switch and the cigarette lighter. Ive spent aroun £60 so far replacing the dash loom, headlight switch, cigarette lighter, ISO connectors etc
I think I'll replace with red LEDs to match the interior.
robanniversary which ISO connectors did you need? and did you have to remove the dash?
1982 3 Door - 'BRO' - gone to pastures new
1990 Clipper Cabriolet - Jet green metallic
amazes me that the circuit isnt fused though! I'll be adding a 1a inline fuse when i replace the wire thats for sure.
