Brake servo and m/c upgrade
(In Topic #124570)
Where would the best place to buy from and I know that its risky but would I be better to steer clear of second hand items?
Any advice is appreciated.
Kris
The guide for doing the job is in technical over to the left of the page!!!
Jon
that u want but you may strugle to find one as there getting rare and
the ones u do find people want silly money for. you will be better of
finding a passat of simiarly age to mk2 golf in a scrap yard which there
should be measure the servo to check it is 9 inch then have a look
at the brake peddle if its metal your good to go if its plastic find another.
Once you have found your servo if the mc fitted is looking a bit old try and find one
off a large seat (there will be plenty of them) its quite easy to tell which will fit
the largest i found was 23mm which is big 22mm will be fine you can tell what
size it is as it should have it stamped on the side.
That want i did and it cost me £15 for both just make sure if u split the mc from
servo replace the seal on the back of the mc
Will
