Brake Lines Help
(In Topic #94273)
Brake Lines Help
Hi guys im looking for a set of stainless.braided brake lines for the mk1……anyone found\used a set before?
Any info would be greatly received
Do you mean brake lines or fuel lines (I thought I saw a post recently where you'd fitted some fuel lines).
I use Goodridge braided brake hoses which you can get for ?30ish from GSF, and am really happy with them.
HTH
Rich
HTH
Rich
i think he means complete set of front to rear?? am i correct chris?
best bet is to get the yellow pages out and look for a hydraulic pipe specialists as we had some mae up for a car at work give ur lengths and unions theyll make them up.
i shall try n find a number for the place we used if u wnat, its in leicester though
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
i do mean brake lines....... ops:
Do you mean the solid or the flexi lines?
Braided Brake Hoses
I have just fitted two front (German and Swedish on offer ?31.50) Goodrich braided brake hoses. Hope I have done the right thing as one was an MOT failure although on close inspection I cannot see the excessive damage or leak that was stated on the failure report! Hope it shouldn't have read brake pipe! They were relatively easy to fit although broke an 11mm open end spanner on one side trying to undo the old one! Now have 4 spacers (that stop the hoses from rubbing) that do not fit the new hoses, should I worry? The rear pipes do not have hoses so I have a pair of rears if anyone needs them?
the rears do have flexi hose's there on top of the rear strut and are only short. there solid to the rear brake from the flexi.
I was looking for braided brake lines, not hoses.
to late now but demon tweeks sell pipe and fittings.
