Brake light switch
(In Topic #105956)
Brake light switch
2) get a switch from a later car and then attach to the the column inline with the brake pedal. - this is what I have done, mines held in place with zip ties untill I can come up witha better fix, but it works ok and means the brake lights come on as soon as I move the pedal.
i used an audi 80 pedal switch, because it had a thread on it, so i simply drilled the hole, and put a nut on the other side, now it works perfectly. i looked on other cars like mk2 golfs and passats etc but it has a funny groove/notch it locks in to place on, so just search cars at the scrayard for ones that attach by threading themselves in, not twisting in if you get my drift.
then the 2 wires in the engine bay can have the plugs cut off them, reroute them under the dash, and connect up with some spades, et voila, brake lights with lots of brake port outlets on the MC
hope that helps
JJ
http://cgi.ebay.co.uk/GENUINE-AUDI-80-BRAKE-LIGHT-PEDAL-SWITCH_W0QQitemZ300270367766QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item300270367766&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318
Is this the same as yours?The switchy bit doesnt look that long,like youd have to fully depress the brake to get it to come on?
GrimyFingers said
Scirocco switch worked just fine for me. Fit right into the pedal assembly and only had to run the two wires back into the car and hook them up.
what age of scirocco? Ill look and see if they can still be got for vw as ill have one of these
GrimyFingers said
Doing something that I hate to do, assuming anything, I will guess your ride is right hand drive. The part number for that model will be 322 945 515 and yes they are still sold as they are used in many cars. Your pedal assembly is different from mine unless it is automatic, then close to the same, but it should still work-out just the same. There should already be a odd shaped hole, in line with the brake pedal arm, for the switch to push into and then turn to lock in place.
Sorry I should have said. you are correct mine is a rhd.
Ill have a look tonight and see if the hole is there already for the switch, but I dont think it is as that switch looks kind of like the one I already have,,
