better brakes ???? help
(In Topic #125689)
ANY ADVICE HELLLLP
9" servo from a mk2 + 22mm master cylinder helps the brakes on a mk1, easy swap and pretty cheap.
then there are adaptor kits on ebay which allow you to fit mk2 g60/early MK3 GTI/VR6 280mm calipers & carriers, cheap but effective.
I have fitted standard mintex friction items all round to my mk1 tintop, new flexis ,refurbed calipers & brake fluid flushed lots of times & my brakes are excellant
baz
the back end is so light any real force at the back would just make em lock up, unless you put a ton o weight in the boot
Can you fit a rear MK2 axel or do you just fir the calipers and disks?
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
i did have rear discs on my cabby, but thats only cos they came with a beam i bought to replace the knackered one on there
you can make them work in a MK1 using a bias valve, what i meant was with this valve fitted they do next to nothing. even with a weighty ass cabby they still wont be doing much in comparison to the front, and they certainly wont offer any braking improvement over rear drums.
as i say, they just look nicer
Sounds to easy, bet their is a catch !
