Best fuel pump solution for 1.8t 20valve conversion
(In Topic #141677)
Well as title the engine is now in my mk1 and I need to think about a fuel pump solution (my car was originally a 1.1 carb model).
What is the best option, I've got a mk4 fuel pump but its too big to fit anywhere 8O I know people use gti tanks and pumps, are these ok up to circa 250bhp?
Just need a bit of guidance really
Mat
Mat
I used the bosch 044 and removed the acululator and replaced it with a high flow filter.
the 044 in all honesty was overkill the original 1.8 8v pump was man enough although mine's little inlet filter was full of swarf when i removed it.
hope this helps.
hope this helps.
VW t4 - tdi conversion
VW golf series 1- 20vt conversion
Peugeot 205 gti track car
so lift pump in a gti tank, a big fuel filter then a bosch 044?
mat
mat
Sorry to hijack the thread but am i thinking that i will need to change my tank from the 1.3l orig to a gti 1.8????
A standard GTI set up is more than enough, with or without the accumulator. The k-jet fuel pump can cope with a lot. Just make sure the standard fuel filter is correct for the engine type your putting in.
Cheers,
Adam.
Cheers,
Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
as above gti pump is good for loads of power.
with that you have 2 choices, either fit a late cabby, rocco or g40 shape polo lift pump and plastic fuel reservoir with your old carby tank, or fit a proper mk1 gti fuel tank with in built swirl pot (some cheap pattern tanks dont have them!)
you dont need the accumulator so bin that, fit a barbed m12x1.5 banjo adaptor and then you can use push fit rubber fuel lines or later vw plastic lines
Well I've got a gti lift pump so that should go straight in my carb tank?? Then gona use a big fuel filter and one of the Bosch 044 jobbies.
Don't suppose you remember what filter you used do you?
Mat
Mat
if its a mk1 cab or scirocco lifter then it'll drop right in yeah, mk2 one wont. any efi type inline filter will do, i.e. mk2 digifant gti or mk3. mk3 comes with a handy filter carrier which might be useful too you
Thanks for the info, yeah it's a mk1 gti pump so thats that sorted atleast.
Mat
Mat
