Best fuel pump solution for 1.8t 20valve conversion
(In Topic #141677)
What is the best option, I've got a mk4 fuel pump but its too big to fit anywhere 8O I know people use gti tanks and pumps, are these ok up to circa 250bhp?
Just need a bit of guidance really
Mat
the 044 in all honesty was overkill the original 1.8 8v pump was man enough although mine's little inlet filter was full of swarf when i removed it.
hope this helps.
VW t4 - tdi conversion
VW golf series 1- 20vt conversion
Peugeot 205 gti track car
mat
Cheers,
Adam.
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
with that you have 2 choices, either fit a late cabby, rocco or g40 shape polo lift pump and plastic fuel reservoir with your old carby tank, or fit a proper mk1 gti fuel tank with in built swirl pot (some cheap pattern tanks dont have them!)
you dont need the accumulator so bin that, fit a barbed m12x1.5 banjo adaptor and then you can use push fit rubber fuel lines or later vw plastic lines
Don't suppose you remember what filter you used do you?
Mat
Mat
