best fan to use for a 2.0l 16v conversion
(In Topic #90597)
cheers rob
Web Team
did you use an aftermarket fan or the whole fan unit from the clio?
Web Team
also hope you dont mind me asking you all these questions.
with regards to the fuel lines i am going to run mine inside the car as i will be useing twin 45 dellortos and have all the filter king and facit pump etc etc. i assume the fuel line runs from the carbs into the filter king then into the cockpit at this point you connect the fuel hose onto copper a single copper line or do you still use the twin fel lines as with the stndard injection ? if you use a single fuel line this will then run through the fuel pump into the fuel tank. im not ure if any of that made sense. youe help would be very greatful.
