Bee sting aerials.
(In Topic #72811)
Bee sting aerials.
My original one is broken and i need to replace it, but i like the lazy idea of not having to put it down ever night.
And i have a spare incase somebody does break the bee sting. 8)
Guest user
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
skid said
The 16v aerial has an internal amp so its reception is pretty good.
GSF have both amplified @?12 & non amp @?8
Windowscreen aerials generally have worse reception
If Its Loud and Noisy , I'll take its picture
crazyquiff said
Expect roof leeks eventually with a bee sting.
…depends how well you seal it. Dont just rely on the 'o' ring that will eventually go hard. Use flexible seam sealer aound the hole, then no worries.
As for roof leaks, as long as its sealed properly it WILL NOT leak, I haven;t had a leak and this was before I stopped driving it in the rain
PhillTMK1GTI said
I just wouldn't feel comfortable drilling a hole in a perfectly good roof!
Yep, I remember when I did mine, lots of masking tape, a steady hand, a sharp drill bit, and a deep deep breath. Rook is a little flexi as well which doesn't help Not for the fainthearted !! :wink:
I can imagine how much of a fool you'd feel cutting the sunroof hole too big…
i currently have an attractive 'ripped-off' ariel and as you can imagine the reception is fairly bad. If i could get reception from the element, i'll fill the hole on the wing . . .
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Racing is life . Anything before or after is just waiting - Steve McQueen
What the hell would happen if you made a mistake …..and the hole was too big ……?
Fit a webasto but what if you cut that hole to big 8O .
What would you do if you slipped with the drill when drilling the hole for the bee-sting aerial or drilled the hole off centre…. you'd have to fit two side by side to balance it out :wink:
1983 1100 C
1983 1100 C
You'd have a Clipper
