Audi 80 throttle body?
(In Topic #101103)
Many thanks luke
m6m62 said
The butterflies will foul on the inlet manifold if you just bolt it on. It'll fit but you won't get full throttle. You need to open up the mounting face / inlet area of the manifold with a dremel
What about the other suggestions I made? I'm thinking of a little bit of a subtle upgrade to the old Storm….
soooo… to get the full effect you need to open up the inlet fanimold (without letting too much grit, waste ali grindings fall into engine), fit a audi WUR and vac pipery. Not quite as simple as simply bolting on a TB.
Linkage differences
Welded mK1 throttle cable item
Audi item fitted after porting the original item to fit
Finished item blasted and painted ready to fit
More air in the engine = better running and possibly more power . 8v when fitted with this was certainly a lot more responsive . If it was of no power gain why did Audi fit a larger item ?
i just swaped them over! and worked for me
mk1 golf gti in porsche ocen blue and polished porsche 7slots
As for modding the inlet manifold, make a paper gasket that fits the throttle body mounting face then place that on the manifold. Dust with a paint aerosol and that'll tell you what metal needs to be removed. Alternatively bolt the TB to the mani, partially open the butterflies (can't open fully - it'll foul !), and scribe marks on the manifold mounting face.
For reference here's an Audi TB loosly mounted on the Gti manifold. Note the mounting face of the manifold visable through the TB :
And here's an opened up Mk1 manifold so as to accept the Audi TB :
http://homepage.ntlworld.com/alanb2/golf/mods/throttle.htm
1989 VW GOLF GTI CABRIO
1997 VW POLO 1.0L
2003 VW PASSAT TDI 130 SPORT
1997 VW POLO 1.0L
Many thanks, Liam
'89 Triple White GTi Cabriolet.
<p>
'73 Turkish Mint Green Beetle.
