audi 80 coupe 2.6 v6 Calipers and Carriers!!
Basically i can get these calipers and carriers as well as the discs and pads, is this a direct bolt on to my mk1 gti cabby to make it 256?
1993 Cabby Rivage
i dont know about an audi but the mk2 golf 16v discs are 256 so they might fit and the golf is a strait swop its when you bigger thats when you start to need adaptors
he who dares rodders
The discs are but the calipers aren't……you need to use either Vauxhall components, or Audi calipers/carriers. I think the "Audi 80 coupe 2.6 V6" (can you confirm the model, that's not a model of Audi!), well the engine size you've quoted, is a later model from the ones that do fit (you're looking for the calipers and carriers). For info, the calipers are the same on later Mk2 Golf GTI 16V and the correct Audi.
PLEASE DON'T POACH THIS GUYS!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130293591293&ssPageName=ADME:X:RTQ:GB:1123
paul thats the link with the car info, he says he wants ?140 posted for the whole front brake setup seems a bit pricey to me.
I just need to know if they will fit!!
On Ed38 im picking up a mk2servo and mc from 16v, hes got the disks calipers and carriers aswell. But if they wont fit there is no point… :dontknow:  :banghead:
1993 Cabby Rivage
Mk1 -> 256mm Brakes
The correct caliper and carriers need to convert your Mk1 to 256mm brakes can be found on :
Audi 80 quattro (83 to 85)
Audi 90 5-cylinder (85 to 87)
Audi Coupe 5-cylinder (85 to 88
Scirocco 16V (if you can find one !!)
Note:- Pads and Discs from the same vehicles will also be needed. >88 Mk2 16v discs and pads are also compatible with the conversion despite the calipers and carriers not being so.
The specific part numbers for this caliper carriers (if bought new from VAG are):-
Part Numbers:-
Caliper carriers - 853 615 125 (x2)
Carrier bolts - N900 689 02 (x4)
Sliding pin bolts - 321 615 141 (x4)
chudd said
Mk1 -> 256mm Brakes
I'm sure the 256mm front calipers from a mk2 golf 16v were fine for this conversion - and the only troublesome part to source were the carriers (which can be found on those Audis)?
sciroccoregisterforum.co.uk • Index page
All MK2 16V Calipers were the same afaik - Girling 54.
It is just the carriers that are different.
I think that the hub to carrier bolt hole spacing is 74mm on the mk1 and 94mm on the mk2 and other Audis of the same era except the ones that Chudd mentioned.
Cheers,
Ade
wouldent  be easyer and cheaper just to put mk2 16v 256 dics and calipers :dontknow:  as thats what iv done on my mk1
The 16V calipers can't bolt onto the Mk1 hub carriers (the bolt holes are different distance apart)…..not without the Audi caliper carriers discussed above. How did you do it without using these?
yes tho but the holes that bolt the carryer to the hub are the same so you just use the carrer of a mk2 and it bolted to the hub
inderstand what your saying paul but i got mine from a show and he said that they was off a mk2 and that they would fit and they do so does this mean they are scirocco :dontknow:
As I understood things, the Mk2 doesn't use a caliper carrier, the caliper bolts directly to the hub carrier. So you must have the Audi/Scirocco 16V caliper carriers (they are the same thing, see chudd's post with part numbers).
Black bit is the carrier :wink:
I am massively confused now!
Can somebody literally just tell me wat to buy, i know it sounds ignorant but i really dont have a clue and don't want to fork out on the wrong parts!
1993 Cabby Rivage
