Another 20v Turbo question help required PLEASE!!!!!
(In Topic #110449)
Got myself a mk1 which i've had garaged for years after never touching the road following a dubsport MK2 8v engine build inc flowed and ported head, fast road cam, twin 40's, bottom end rebuild etc which is now up for offers or swaps for 20v ecu bits
So my problem is this, we own a scrap yard and the other day turns up a mk4 golf gti (ARZ Fly by wire pedal)(No key) so i get the stupid idea whist doing everything else lets start on the mk1 again.
Before everone starts i've read every 20v post i can but not got all the answers i need so here goes……
Removed the engine and the engine wiring including the ecu and the four or five plugs that plug in under the wiper motor no futher on the other plugs except the one that runs to the pedal.
I have also found lay around a 306 coil pack, a laguna top hose, already got 020 box, and i've taken a mk3 gti throttle body off which looks a perfect fit and is of the cable type.
So i need to know what do i find a map sensor thats suitable on what car of van? and what engine management should i use with the following question….
Does anyone have a wiring diagram for the remaining plugs that go to the car and i'll install the fly by wire pedal and then who knows who and a ruff price for an ecu defeate (Can i do it this way?) Also what would i do as i notice there is 2 lamba sensors installed but i'll only be running 1 can the ecu defeate deal with this?
Or go with the mega squirt and install the mk3 throttle body the wiring for me is easy but where can i get the right mega squirt with the right software and codes and from what i've read resisters??? How much?
Or can i use the software people have got and use a mini squirt like the on for sale currently on ebay?
Other places then QP for downpipes?
Dim's for the drives mount that i need to make?
Or last resort do i go to qp engineering for the down pipes and ecu?
I'm based in manchester
Thanks for any help
