Alloys
(In Topic #92168)
Alloys
Tian
solution, grind the carrier face flat or take em back.
If its only a few mm just use spacers.
basically they should fit but depends on the design really.
Looks like I need some 5mm spacers then.
Tian :roll:
Topoftherange said
you can get thinner spacers than 5mm try ebay or demon 2 weeks, it only has to clear the caliper by .1 of a mm as it cant move once its fitted, you can also get this problem with some rim types when you renew brake pads too!! as it pushes the caliper out further
You're absolutely right, I've just got back from ECP with a set or two 3mm spacers.
I now have to make Jam Tarts with my boys and a mates kid too, it's Half-Term homework and I'm the lucky chap that's got to do it.
Tian :roll:
…… Heres one i made earlier!
Tian :mrgreen:
Does anyone know where I can get hold of nuts that are a bit longer, just to make up the difference added by the spacers.
Tian :dontknow:
I think their website is www.mswuk.com
i've always advised that vw factory alloys seem to work better than any aftermarket jobbies. they are designed with the vw mk1/2 in mind.
wooders said
post some piccies. they better look good or i'm going to slate em.
I know what you mean, I was after a set of BBS wheels in 15 inch but kept being out bid. I had just been out bid on a set in SE London when I saw these and decided enough was enough, I needed tyres and I wasn't going to pay for a set to fit my old 14 inch wheels. I'll get some pics up later.
Tian
And our survey says?
Yokohama rubber is so nice, grippy as a very grippy thing with extra grips attached with a super sticky coating of extra grab contact glue.
Tian
wooders said
if i stand away from the puter and squint a little, they look lovely.
I'll take that as a result!
Tian
Topoftherange said
Look nice 8) , are they DTM Mesh alloys? very arty shot there :wink:
Thanks, they're alright especially for the money. One had a new tyre fitted and they only came to ?100.00 off the bay. The three remaining tyres came to just over ?120 so all in all just ?220.00 for a full set of alloys and tyres, not bad eh?
These are nice though, don't know what lucky bugger's got these.
Tian :mrgreen:
what name/brand are they ?
I am always on the hunt for BBS RM`s so if i get anymore i will shout you, if you fancied a change in the future, i got a few German contacts recently so getting the rims or bits to refurb them has got a bit easier and cheaper :wink:
