ABF on twin 40's which Distributor, Help Please.
(In Topic #142336)
I am currently putting an ABF engine into my MK1 gti. When I baught the car it was running an 8v on twin 40's so i only have a carb loom and a coil. The project is going well with the engine in and only a few jobs left to do.
I am abit unsure of which distributor to use with the carb loom, can i use the ABF one with the coil or do i need to use a 205 gti one with vacuum advance.
Any help would be great
Martin
you'll also need a mk2 golf coil as the mk1 unit will have an incompatible lead fitting
Thanks for your help.
this is how you wire it up, couldnt be easier:
1 - Earth to battery -ve
2 - KR ign controller plug
3 - TCI-H plug
4 - Black - KR ign controller & TCI-H ign live - terminal 15 side of coil
5 - Green - Coil trigger - terminal 1 side of coil
\- red/black - spade is for the isv control unit, the main wire is the rev counter feed
6 - Brown - Earth to cylinder head
7 - Blue/white - Temp sensor feed (use one of the 3 on the side of the head)
8 - Dizzy plug
9 - red/yellow - Fuel pump relay earth trigger
\- black/yellow - idle switch feed (12v feed with throttle shut)
