ABF into an 89 1.8 clipper carb. A few wiring questions
(In Topic #96799)
However Ive been crawling through loads of posts and cant find the info im looking for.
Basically if i want to put an abf into my carb, what will i need to do that different to the normal guide?
Aren't the fuel pipes already in the right place on the carb? Can i get away with using the carb fuel pump and piping?
As for the wiring im completely lost other than i know id like to use the efi for the abf. Any help appreciated.
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
gti fuel tank
gti fuel lines
gti fuel pump
gti accumilator
and so on pm paul_c hes done said conversion :wink:
bens_cab said
you need
gti fuel tank
gti fuel lines
gti fuel pump
gti accumilator
Don't PM me - I don't know! I did GTI to 9A (retaining K-Jet) so didn't have to mess about with the fuel system. Essentially, you'll need to add an electric fuel pump - I think Ben's got it about right - use the GTI stuff.
you will need another fuel pump, e.g facet red top
you wont be able to run the abf with your crappy pierburg carb so chuck it.
you need to get in touch with emerald and fork out ?500 for their new k3 standalone ecu as its the quickest,simplest and most reliable way, all the sensors on the abf will plug straight into the k3 and they will supply you with a base map to get you going.
if you dont understand any of this your probably not qualified to do the conversion and need to educate yourself a bit more, sooo many people think they can quickly do an engine swap and end up with a box load of bits on ebay and a stranded car.
not saying this is you, just offering my advice as im doing the same conversion :wink:
Mk1 '92 cab ABF Jenveys & Emerald
2004 Mk1 Fabia VRS
2002 Audi A4 Avant 1.9tdi
2004 Mk1 Fabia VRS
quikclipper said
you need to get in touch with emerald and fork out ?500 for their new k3 standalone ecu as its the quickest,simplest and most reliable way, quote]
if you can get emerald that cheap goodluck
failing that pm me and ill hook you up with a megasquirt for ?300
or just use the abf ecu?
?560 i was quoted
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
quikclipper said
?560 i was quoted
what they fail to tell you is all the other bits you need like loom plug sensors ect ect comes in close to a grand m8
i priced one up last year just out of interest to see how cheap it could be done
oh plus ?400 rr session 8O
mk4 rear disk
webber carb
mk4 rear disk
webber carb
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
quikclipper said
all the sensors are still on the motor, 400 quid for a rr sesh, you must be joking!
no thats why most people try to steer clear of it
mk4 rear disk
webber carb
mk4 rear disk
webber carb
Anyone else with info on useing abf ecu?
mk4 rear disk
webber carb
mk4 rear disk
webber carb
http://membres.lycos.fr/philippe840/phpBB/viewforum.php?forum=1&106
p.s just2zang, just noticed you have a weber not the 'crappy pierburg' i told you to chuck. ops:
2004 Mk1 Fabia VRS
2004 Mk1 Fabia VRS
Yeah i even had a spare pierburg so now i have two. Pile of junk.quikclipper said
Installed webber, in little over an hour taking my time in snow, and was running great after just a little adjustment of idle. Dont like the airbox bracket for the screw though, seems to get in the way of the throttle flaps.
mk4 rear disk
webber carb
mk4 rear disk
webber carb
