ABF dizzy cap on KR dizzy
just in the process of doin an engine conversion in my caddy,does anyone kno how i can fit an abf cap onto a kr dizzy or do i have to use a dizzy from an abf lump  :dontknow:
any help wud b muchly appreciated  :)
It would be a good start if you advised what engine your fitting and what the issue is  :dontknow:  so we can help
:redfaced:  :redfaced:  just dropped an 1800 16v kr lump into my caddy,problem ive got is the kr dizzy dunt fit due to the brake fluid resevoir bein in the way,i got told to use a dizzy cap off the 2.0 16v abf lump only prob is that bolts on where as mine clips on or is the another alternative cap i can use
take the brake fluid resovoir off and turn it around job done
and use the original kr dizzy cap yeh
has anyone got a mk2 gti brake servo,master cylinder and reservoir,need to upgrade everythin anyway
no leave reservoir right way round, even if you flip it the hard lines still get too close to the kr cap, ive tried it myself. what you do is rotate kr dizzy 180 degrees then the abf cap fits perfectly without any hacking, just have to use an 8v king lead as 16v one wont quite reach.
kr cap, far too close for comfort:
abf cap, bags o room:
